Sleight Engine Knock in a 04 4.6 v8
Old Aug 11, 2010 | 11:47 AM
bulldozer32's Avatar
Default Sleight Engine Knock in a 04 4.6 v8
Before taking my truck in to my local dealer for minor service (non engine related) I begun to notice engine knocking while at idol. I run 93 octane gas, (sunoco) and I am curious as to why the engine is knocking. The odd thing is that after taking it in for service the knocking is almost gone. But I have a feeling it will be back soon enough. What can I do to ensure that it won't come back.
Old Aug 11, 2010 | 12:01 PM
sloan74's Avatar
You sure it's a knock? I am no expert on these engines but it could just be the lifters (which is normal on high mileage engines). You said it only does it at idle so that is why I am suggesting it. The reason it goes away right after service is the oil change more than likely (the oil viscosity breaks down according to weather/driving conditions and sometimes you will hear the lifter noise and sometimes you will not depending on the oil type/condition). You can hide it with different oil weights/viscosity sometimes, least that's what we do with the Jeeps (Jeeps are my only insight atm I am new to Land Rovers). To totally fix it, it was easy to readjust the lifters in the Jeep 4cyc, but the 6cyc is was a pain in the ***. I am asssuming it would not be fun on a DiscoII V8 either, but someone else will have to help with that who has worked on these engine.
Yeah, a knock is loud man. And it would not go away after idle. It would get louder (speed up). You would be freaking out. hehe
If I am totally off here, I am sorry. New to the forums, just trying to help.
________
green crack pictures
Old Aug 11, 2010 | 12:46 PM
David A's Avatar
Ticking or knocking?
Old Aug 11, 2010 | 04:36 PM
Hey thanks for the insight, i guess its more of a ticking its not that noticable at driving speeds but at idol its pretty noticable. I am running 5-40w synthetic oil. But also I have just below 60k on the engine. So I'll talk to my service manager and ask him about the lifters.
Old Aug 11, 2010 | 04:37 PM
by the way sloan74 welcome to the forum. Its a great community.
Old Aug 11, 2010 | 05:01 PM
sloan74's Avatar
Awesome!
________
Big dick tight
Old Sep 3, 2010 | 05:21 PM
sito007's Avatar
I have a knocking sound when i start to press the gas and after a while it almost goes away but now sure what going on.. i used to have regular oil and the last oil change i switched to synthetic oil. could that cause problems?
the sound i think is coming from the bottom. could it be the heads or gaskets? or maybe the cranshaft?
Old Sep 3, 2010 | 05:38 PM
What oil are you using? What weight? How often do you change it?
Old Sep 3, 2010 | 11:26 PM
'BamaBoy's Avatar
Mine had a slight ticking at idle. No additives or synthetics would fix it. I threw in Royal Purple 5w30 in it, and it quieted down right away. My family told me "Something's wrong with your Rover Alan....it's too quiet". My oil consumption went from 2 quarts every 3,000 miles to Zero quarts every 3,000.
Some people love the oil, some people dispise it. I guess it really depends how much you're willing to pay to get rid of that knock
Old Sep 4, 2010 | 12:17 AM
bosshogt's Avatar
Wow BamaBoy that was a lot of oil consumption. Did you try Mobil 1 10w40 high mileage. Just curious. I use a less than 1/4 of quart per 5000 miles. I know Royal purple has great oil. Seems like its worth its price if it cures your problem. I have debated putting it in my diffs and TC case. Or go with the Tech stuff from Walmart and change it more often. (like Spike does)
