Slider install issue w/ ACE accelerometer
Old Jan 18, 2014 | 03:59 PM
acamato's Avatar
Default Slider install issue w/ ACE accelerometer
I was installing my TF sliders today. Drivers side went on fine without any interference issues. When I got to the passengers side, I went to put it over the sill to mark hole locations and discovered I have an interference issue. There is a sensor on the inside of the passenger sill in the area of the ACE block. I think it is the ACE accelerometer.
I have two options on how to deal with it:
1) drill out the rivets and relocate it onto the slider.
2) notch the silder
What should I do?
Does anyone know what size rivet LR uses?
http://www.flickr.com/photos/40952238@N04/12019050814/
Old Jan 21, 2014 | 08:13 AM
acamato's Avatar
I ended up relocating the ACE accelerometer to the slider. I used 3/16" x 1/2" alum rivets to secure it. I drilled thru the sill and slider for the rivet hole.
Now the amber ACE light is on. From doing some searching, a calibration of the accelerometer may solve the issue.
Old Jan 21, 2014 | 08:22 AM
drowssap's Avatar
i think i would do the same thing, loosen the accelerometer leave it hang by the wires, mount the slider and re-install the accelermeter using self tapping screws.
Old Sep 21, 2021 | 02:46 PM
fjellfant's Avatar
4th Gear
Default Same happened to me 10 years later!
I installed the rock slider, and were very suprised that there were an obstical under there. I did relocate the sensor, and second suprise. The amber light is on. Did you manage to fix it?
Old Sep 21, 2021 | 03:00 PM
Best4x4's Avatar
My 99 had that sensor held on with a funky rivet. Drilled it off, mounted rock slider then really secured the sensor. My came on when I drove it. Had to use the Nanocom to clear the fault/calibrate it and it's never come back on.
Old Sep 22, 2021 | 12:59 PM
RoverSE7's Avatar
Boy these Discos are finicky.
Old Sep 22, 2021 | 01:14 PM
Best4x4's Avatar
Not really that yaw sensor is critical to how the ACE functions. If it's not calibrated correctly the ACE system could misread the readings from the sensor and cause a ram to activate incorrectly which could possibly cause an accident.
Old Sep 22, 2021 | 03:57 PM
fjellfant's Avatar
4th Gear
I deleted the fault codes with nancom. But they come back at once. Is the sensor broken, and I should buy a new one (I did accidently drop it on a concrete floor.)?
Or is it something else. From what I could find the sensor get earth from the yellow and green cable, so it shouldnt be the painted pop nails i used.
Old Sep 22, 2021 | 04:00 PM
fjellfant's Avatar
4th Gear
Can you calibrate with nancom or is it something for LR workshop?
Old Sep 28, 2021 | 11:07 AM
nashvegas's Avatar
FYI the Rovers North sliders (their brand, they are very very good) have a notch and provision in them for this exact ACE sensor. I left the sensor as is, slider fits around it.
cornercase
May 24, 2013 11:43 AM
earlyrover
Apr 30, 2013 03:33 PM
jycsalas
Dec 17, 2008 11:00 AM
POPPY1
Oct 28, 2007 11:38 AM
alrd
Nov 17, 2006 11:25 AM
