slight miss at idle no codes....but
Old Sep 3, 2010 | 10:13 AM
agthird's Avatar
Default slight miss at idle no codes....but
just wondering how smooth should the engine idle warm?
Old Sep 3, 2010 | 12:42 PM
lipadj46's Avatar
It should be very smooth, check and see if one of your fan blades is cracked, check your engine and transmission mounts as they tear easily, clean out your idle solenoid with throttle body cleaner.
Old Sep 3, 2010 | 01:13 PM
agthird's Avatar
where is the idle solenoid located?
Old Sep 3, 2010 | 01:16 PM
lipadj46's Avatar
Its that tin can looking thing above the intake with 2 hoses connected to it.
Old Sep 3, 2010 | 01:52 PM
agthird's Avatar
okie doke...thanks
Old Sep 3, 2010 | 02:12 PM
What octane gas are you using, have you done an induction clean yet? I would stay away from the idle solenoid for now, most likely isn't the problem and too many people have screwed them up trying to clean them.
Did you also change your air filter, are you using paper or K&N type?
Old Sep 3, 2010 | 02:24 PM
agthird's Avatar
paper filter...93 octane...new plugs and wires...tell me about induction cleaning please sir...
Old Sep 3, 2010 | 02:41 PM
agthird's Avatar
neve rmind saw the write up will do the seafoam thing....
Old Sep 3, 2010 | 03:11 PM
If you want to do it right, use a whole can of Seafoam for the induction cleaning and throw a can of BG's 44K in the gas tank before a couple hour trip on the highway.
Old Sep 3, 2010 | 03:13 PM
agthird's Avatar
okay can do that thanks Mike...
