Slightly comical problem with left blinker
Old Nov 21, 2012 | 12:50 AM
Unlikely that it is the stalk switch, because it just signals the BCU. The BCU signals the IDM behind the fuse panel to do the flashing for left or right. See factory wiring diagram on page 97 of 152 in the circuits manual of the D2 portion of the RAVE. Might try unplugging head lamps on that side to eliminate connector issues up front.
Old Nov 21, 2012 | 06:16 AM
coors's Avatar
The problem is definitely related to a grounding issue. Check your negative battery cable to make sure it tight.
Next remove your driver's side sunvisor (3bolts) and check the wire that feeds the vanity mirror light. Be sure to inspect as much of the wire as possible. Overtime that wire gets twisted and frayed from swinging the visor/mirror back and forth. Ask me how I know. I got a sweet deal on my Rover because the previous owner was having the same issues as you and after weeks of battling with the problem - sold it to me for dirt cheap.
If the drivers side checks out fine move over to the passenger side.
Old Nov 21, 2012 | 09:01 AM
According to the RAVE circuits manuals (diagrams) and troubleshooting guide (pix of connectors and locations) the attached C0017 is one of many ground headers. Also may be one under the carpet. In the words of the infamous James R Lee, "son, you can't have ground buckin' ground".
File Type: pdf
Old Nov 21, 2012 | 09:23 AM
bballjames's Avatar
Thanks guys for the info. I will start to dig a little deeper and see what I can find. I appreciate the help.
Old Nov 27, 2012 | 12:21 AM
bballjames's Avatar
So now all my left hand signals stay lit even when the blinker is not activated when my lights are on. They are not lit when the lights are off. Everything on the dash still flashes when the left blinker is turned on, but nothing flashes when the lights are on, but the signals are all lit all the time when the lights are on. I can't seem to figure out the source of this issue. Have any ideas?
Old Nov 27, 2012 | 06:23 AM
ghengis86's Avatar
You're low on blinker fluid and need to top it off.
Is there a flasher relay/fuse?
Old Nov 27, 2012 | 09:29 AM
slabrat's Avatar
Now that was funny.
Old Nov 27, 2012 | 10:42 AM
bballjames's Avatar
Haha I wish it was that easy.
I have checked all my relays/fuses and they are fine. Like coors said, it has to be a grounding issue, I'm just not sure where to look...
Old Nov 27, 2012 | 08:50 PM
shady milkman's Avatar
Geez, no way...mine started doing the exact same thing today...the only thing I noticed is that on my trailer adapter, one of the four green lights is out when my trailer is attached...it's got to be some kind of grounding issue or fuse
Old Nov 27, 2012 | 09:30 PM
bballjames's Avatar
Well if you figure it out be sure to let me know. I've checked all grounds, fuses, and relays that I can get to and haven't found the problem yet...
