Slip Joint Question
Old Apr 2, 2008 | 12:20 PM
tee51397's Avatar
Default Slip Joint Question
If I just leave a zerk/grease fitting in the front prop shaft will I need to get it rebalanced? I searched and couldn't find an answer.
Thanks,
-T-
Old Apr 2, 2008 | 12:48 PM
Urban Panzer's Avatar
Default RE: Slip Joint Question
Mines still in there, has not seemed to cause any issues yet.....
Old Apr 2, 2008 | 01:07 PM
tee51397's Avatar
Perfect, Thanks!
Old Apr 2, 2008 | 07:48 PM
No, but you do stand a chance of teating it off of the drive shaft when it gets hit, and if you go play much, it will get hit, so go put the old factory plug back in and use the grease fitting to lube it only.
Old Apr 2, 2008 | 08:32 PM
tee51397's Avatar
Good Point, didn't even think of that. Not much question as to how quick it would be gone.
Phototone
Apr 24, 2008 05:15 PM
hasallhisteeth
Feb 6, 2008 06:55 PM
beyondyonder
Jul 2, 2007 10:17 AM
mowthat
Mar 18, 2007 05:44 AM
dickensheets
Oct 6, 2006 02:53 AM
