Broke the slip yoke HELP CDL
Old Mar 17, 2007 | 01:06 AM
mowthat's Avatar
Default Broke the slip yoke HELP CDL
I was changing the u-joints on my front shaft and broke the slip yoke u-joint ear. How do I engage CDL so I can move this thing???? Also anyone know of replacement slip-yokes? Or do I need the whole shaft>?
Thanks for the help. 2000 disco II se7
Jake
Old Mar 17, 2007 | 02:24 AM
piotrsuw's Avatar
Default RE: Broke the slip yoke HELP CDL
Jake,
If you crawl under the car and feel around up above the front output shaft flange - you will find a flat, horizontal surface on the t-case casting. On top of it is the CDL engagemet stub. It needs to be turned trough 90 or so degrees - I forget if it is clock wise to engage or the other way. Let me know if you can't find it - hard to explain without a picture... How did you brake the yoke? Guessing you were using something to press out the bearing cups? These should be tapped out instead (from the inside outboards after you remove the circlips). It is kind of a pain...
Piotr
Old Mar 18, 2007 | 05:44 AM
mowthat's Avatar
Thanks for the quick response. I got cdl engaged and im on the search for a replacement yoke or whole shaft. Guess thats what I get for trying to save some money by doing it myself. Live and learn.
turbodave
Mar 29, 2019 07:22 AM
98P38
Dec 28, 2008 01:30 AM
hasallhisteeth
Feb 6, 2008 06:55 PM
beyondyonder
Jul 2, 2007 10:17 AM
dickensheets
Oct 6, 2006 02:53 AM
