Is this a slipped liner...???
Old Jul 3, 2021 | 05:47 PM
logicmike44's Avatar
Default Is this a slipped liner...???
In process of replacing head gaskets due to combustion in coolant that caused overheating and eventually white smoke from tail pipe.
After removing both heads, there were no visible signs of blown gaskets. There was major clogging in the passages near the firewall.
So looked closer for signs of slipped liner.
The cylinder closest to the firewall appear to have a small gap below the surface, but not all the way around.
Old Jul 3, 2021 | 06:56 PM
The Deputy's Avatar
Okay, pictures are not the best...but...l've added some markers to distinguish different areas.
White markers are cylinder bore.
Red dots are along lip of liners outer edge, which is flush with block surface. (you can faintly see circle that goes around bore about 3/16)
Yellow marker is top of piston.
l'm not seeing any signs of slipped liner. Circular ring, liner edge, looks firmly in place and is flush with block surface and there doesn't seem to be any "steam-cleaning" on piston surface.
That ridge/groove round liner upper edge is unusual, for sure, but, not sure if it was done by sloppy piston (bad rings) or made by someone in there previously (ring ridge removal tool) or poor machining from manufacturer.
craigfial
Jan 24, 2022 10:43 AM
jtunio
Dec 11, 2020 03:13 AM
pchilof
Oct 26, 2020 10:56 AM
GTFNK
Nov 11, 2019 10:22 PM
GBtommyHRH
May 5, 2018 02:30 PM
