Replacing a torque coverter
Old Jul 2, 2021 | 08:45 PM
BPillen266's Avatar
Default Replacing a torque coverter
I am replacing a transmission on my 2000 Disco II. The case got cracked when the front drive shaft broke loose. I need to add the torque converter to the new tranny. Do I need to fill it first, or when I start the engine the pump will fill it and I have to maintain filling the tranny pan as it runs?
Also, how to align the torque converter to insure it is seated correctly?
This is the first LR I have owned, it is a bit different to work on, but having a growing appreciation for them.
Much appreciate your help.
Old Jul 2, 2021 | 10:58 PM
Richard Gallant's Avatar
@BPillen266 it is easy to screw up - if you can afford the tow and cost get a transmission ship to put it in. If not get a copy of the RAVE and read through the procedure. 44.37 has the refit but there is whole section just on the transmission
Old Jul 3, 2021 | 05:37 AM
BPillen266's Avatar
Thank you, will look this up. I believe I have the procedure for installing and measuring to ensure it is seated and will have clearance when installing the tranny. What I have not seen is if you need to refill the torque converter before you install it. I will look for RAVE.
Thanks again,
Old Jul 3, 2021 | 07:10 AM
zski128's Avatar
Yes typically you would fill the torque converter as much as you can before installing.
Old Jul 3, 2021 | 07:19 AM
mollusc's Avatar
Should be able to download the RAVE from www.landroverresource.com
Old Jul 3, 2021 | 07:26 AM
mollusc's Avatar
RAVE does not say to fill the torque converter separately. Page 44-37.
Old Jul 3, 2021 | 07:50 PM
The Deputy's Avatar
Usual pour a quart in, lubes needle bearings on center hub of converter. I've never installed a converter, new, without filling somewhat first.
While installing converter, tilt trans higher at front, slide converter onto main shaft, holding as straight as possible and turning gentle as you go. It will make three or four positive alignments fellings...but the last one is the most crucial. Normally, once the converter is all the way in...you can not fit your fingers between back of converter and bell housing.
yuri
Nov 8, 2021 07:09 AM
me 2
Jun 1, 2012 11:18 AM
idahorover
Oct 28, 2010 08:12 AM
Engnur
Aug 30, 2009 05:12 PM
