slow brake fluid leak
I have a pin hole leak somewhere in my brake system, I use about 2 caps full of fluid a month. As I have a few things to do when the weather is better, I figured it is time get this sorted out.
There are no obvious signs of fluid, at least that I can find. Any good suggestions on how to track it down, as it is not a circulating system I do not think dye will work. It may be the master but I need to clean up under there to confirm.
Brke pressure is ok not perfect, better after the ABS pulses or a single pedal press.
Richard Gallant (01-07-2022)
@PalmettoDisco that was my 1s thought - but it has been a bit nippy to be out under the hood. I need to do a through clean under there to check it, there is wee bit of dust and crap there.
That’s where mine was leaking from. Had to take it to a local Indy shop for a proper bleed after I put a new reservoir kit on.
Richard Gallant (01-08-2022)
