slow brake fluid leak
Old Jan 7, 2022 | 04:32 PM
Richard Gallant's Avatar
Default slow brake fluid leak
I have a pin hole leak somewhere in my brake system, I use about 2 caps full of fluid a month. As I have a few things to do when the weather is better, I figured it is time get this sorted out.
There are no obvious signs of fluid, at least that I can find. Any good suggestions on how to track it down, as it is not a circulating system I do not think dye will work. It may be the master but I need to clean up under there to confirm.
Brke pressure is ok not perfect, better after the ABS pulses or a single pedal press.
Old Jan 7, 2022 | 04:57 PM
PalmettoDisco's Avatar
A common area for leaks is the rubber grommet under the fluid reservoir. Do a search on here for rubber grommet. Look for a leak directly under the reservoir. A double pronged pin holds the reservoir on. Pull pin towards front of truck to remove for inspection.
Old Jan 7, 2022 | 05:01 PM
@PalmettoDisco that was my 1s thought - but it has been a bit nippy to be out under the hood. I need to do a through clean under there to check it, there is wee bit of dust and crap there.
Old Jan 7, 2022 | 08:39 PM
Tony Luna's Avatar
That’s where mine was leaking from. Had to take it to a local Indy shop for a proper bleed after I put a new reservoir kit on.
Old Jan 8, 2022 | 10:50 AM
Best4x4's Avatar
Other sneaky spots for a seep = caliper pistons. Usually it'll get absorbed by all the dirt/debris/brake dust in the caliper unless it's a massive leak. #1 spot for sure is the reservoir though no doubt.
sickws6
Nov 30, 2013 11:22 AM
NERover
Oct 29, 2013 09:41 AM
ATLDisco
Jun 6, 2012 06:21 AM
SurfRat
Oct 14, 2008 02:51 PM
unstable
May 22, 2008 08:19 AM
