Brake fluid leak? MC? Wth.
So been noticing little puddle of fluid under front left wheel. After closer investigation noticed it's seeping through the abs grommet hole. Noticed a little dampness around the mc reservoir can't really tell though.
Very common leak for our vehicles. The brake fluid reservoir mates to the master with basically a press fit. The grommets deteriorate and start to seep.
I've heard rumors that there is a BMW part # for those grommets. However, I've never confirmed. The safe choice is:
Brake Master Cylinder Reservoir Kit (Genuine Part # SJJ100362) - Land Rover kits from Atlantic British
I went with a full assembly (booster, mc and res) used from Will Tillerey two years ago, and so far so good.
handsome rob
Aug 25, 2009 12:30 PM
