SLS compressor
Hey All, Can anyone tell me which relay and pins you would use to jump the SLS compressor? My daughters car right rear bag is all the way down and the compressor is not comming on. I already switched fuses and relays to see if that was the problem. I can it on my RR but am not sure on hers. Any help would be great. Just need to see if compressor is shot.
Thanks All, Chris
Thanks All, Chris
thanks for the reply...yes i know there is a slight leak when it gets cold and i know about the door. It fixed itself today as rovers do magiclly..... I ended up getting a spring conversion kit for a little over a 100 buck .. it was used only 100 miles ..got from my ocal rover guy i know. I will change over this weekend and my daughter will be silenced.. Yea.....
Thanks again, Chris
Thanks again, Chris
smokin
09-06-2013 01:19 AM
EstorilM
05-24-2010 11:03 PM
EstorilM
12-30-2009 09:56 AM
