SLS compressor
Old Mar 10, 2010 | 11:55 AM
vandev's Avatar
Default SLS compressor
Hey All, Can anyone tell me which relay and pins you would use to jump the SLS compressor? My daughters car right rear bag is all the way down and the compressor is not comming on. I already switched fuses and relays to see if that was the problem. I can it on my RR but am not sure on hers. Any help would be great. Just need to see if compressor is shot.
Thanks All, Chris
Old Mar 10, 2010 | 06:12 PM
Its not the compressor thats your problem.
It is either a bad airbag, a air leak, or a bad height sensor.
Old Mar 10, 2010 | 06:13 PM
And the compressor will NOT come on if a door is open.
Old Mar 10, 2010 | 08:29 PM
vandev's Avatar
Default thanks guys
thanks for the reply...yes i know there is a slight leak when it gets cold and i know about the door. It fixed itself today as rovers do magiclly..... I ended up getting a spring conversion kit for a little over a 100 buck .. it was used only 100 miles ..got from my ocal rover guy i know. I will change over this weekend and my daughter will be silenced.. Yea.....
Thanks again, Chris
Old Mar 10, 2010 | 08:50 PM
LOL!! Silence your daughter? Good luck with that!! Mine wont be quite.
Landy Idaho
Apr 27, 2011 07:16 AM
EstorilM
May 24, 2010 11:03 PM
EstorilM
Dec 30, 2009 09:56 AM
humroot
Jul 21, 2007 03:49 PM
