SLS Compressor help.
Old Jul 21, 2007 | 03:49 PM
humroot's Avatar
Default SLS Compressor help.
Thanks to Mike, I am doing a conversion BACK to my sls. I converted to coil springs because the dealer told me the compressor was bad. They also told me that I needed new head gaskets when all I needed was a throttle body gasket. Anyway, I checked the compressor today and noticed that is does blow air. My question is how much air is this supposed to blow? IfI put my finger on the hose, I can stop the air. Is that bad? I'm thinking yes. But before I drop a few hundred bucks on a compressor, I want to be sure.
BTW Mike - I did the Seafoam cleaning last night after I talked to you. Instead of using extra tubing, I followed the vacuum line and used the other end of it. My Check Engine light came on, but I got it off by pulling the battery. I did not get pulled over, but I turned some heads. Also did the ATF flush and put in 10W-30 Royal Purple. My Disco says Thanks!
Jamie
Landy Idaho
Apr 27, 2011 07:16 AM
EstorilM
May 24, 2010 11:03 PM
vandev
Mar 10, 2010 08:50 PM
EstorilM
Dec 30, 2009 09:56 AM
