SLS sensor supply low
Old Jan 8, 2008 | 01:33 PM
ajh's Avatar
ajh
Default SLS sensor supply low
Getting 5v from the left SLS sensor, .15 from the right. Any clues on what to look for? Things went from cold to wet in the last few days so I suspect that it's related. Got about 30 min to fix it though.
Old Jan 8, 2008 | 01:49 PM
ajh's Avatar
ajh
Default RE: SLS sensor supply low
THE SLABS FAULT CODE MEMORY CONTAINS CODES FOR THE FOLLOWING CURRENT FAULTS:
13,3 REAR RIGHT HEIGHT SENSOR SUPPLY OUT OF RANGE OCCURED 0 TIMES.
13,7 REAR RIGHT CORNER VALVE DUTY CYCLE EXCEEDED OCCURED 1 PREVIOUS TIMES.
THE SLABS FAULT CODE MEMORY CONTAINS FAULT CODES FOR THE FOLLOWING INTERMITTENT FAULTS:
13,1 REAR RIGHT HEIGHT SENSOR OUT OF RANGE OCCURED 0 PREVIOUS TIMES.
13,6 REAR LEFT CORNER VALVE DUTY CYCLE EXCEEDED OCCURED 1 PREVIOUS TIMES.
16,6 EXHAUST VALVE DUTY CYCLE EXCEEDED OCCURED 0 PREVIOUS TIMES.
Old Jan 8, 2008 | 02:18 PM
Sounds like you are ready for a new height sensor, lucky for you they are cheap and easy to replace.
Old Jan 8, 2008 | 02:28 PM
ajh's Avatar
ajh
and impossible to get in time.
Old Jan 8, 2008 | 02:51 PM
ajh's Avatar
ajh
Well, the rest of the SLS system will be on-sale as of Friday.
Old Jan 8, 2008 | 04:11 PM
All because of a $30 switch???
Old Jan 8, 2008 | 07:29 PM
okdiscoguy's Avatar
With your hatred towards electronics, you shoulda bought a D1 and threw an RPI 5.2 in it, then lifted.
humroot's Avatar
Don't do it! Stay with the SLS. I switched to coil springs and actually went back SLS because of the superior ride quality. Unless the whole system is shot, I suggest you stay with the SLS. Besides, the dealer will charge you $130 just to tell the computer you don't have SLS anymore. If you don't change the computer, you get the SLS beep consistently....it never goes off.
Old Jan 8, 2008 | 07:31 PM
humroot's Avatar
One more thing...if you do decide to switch, I'll give you $50 for the compressor!
Old Jan 8, 2008 | 09:57 PM
ajh's Avatar
ajh
ORIGINAL: humroot
Well, I've been looking at doing it for awhile. There are a few reasons.
Define "Superior", I find it too soft and swaying now and I'm looking to stiffen things up. I'm also going to mount 12" shortbody Bilstein 7100's with higher than normal rebound/compression damping settings in the spring.
I also want to be able to disconnect the rear swaybar and articulate with either retained or cones in place, the airbags wouldn't allow that either since they really don't like to be unkinked.
I do too much alone, miles away from help, to have this kind of thing fail on me randomly. I did find someone doing a manual override for air bag pressure you could fill using a normal compressor, but it still doesn't seal with the other issues.
I'm not fond of the Caddy-like ride, my favourite cars are all low and tight sportscars, Lotus Exige, MR2, and superbikes like my 900RR with reworked front and Ohlins Type-III in the back with a fair bit of spring preload. So, 'superior' is relative I guess.
KlamathMatt
Apr 17, 2020 05:27 AM
icyhot201
Nov 27, 2012 12:32 AM
Sidewinder6
Jun 9, 2010 11:52 AM
RjBu
Oct 14, 2009 10:31 PM
