SLS spacers ( lifting my discovery )
RTE-Fab has spacers ( 2 in ) that go under the stock air shocks in the rear of my discovery and and under the front coils all for about $225.
My question is first of all after technically lifting the coils the two inches will I also need to by two inch lift shocks to even it out?
Also after these are installed I plan to install a new steering damper and wheel spacers to stabilize it a bit.
lastly has anyone ever heard of these spacers or have any experience with them? Are they safe?
A new steering dampener is fine but the wheel spacers aren't needed.
The spacer lift for the rear air bags is a tried and tested mod and is safe. I would upgrade the shocks all the way around. I'm assuming your doing a 2" lift on the front as well. TerraFirma has been a good shock for me so far and are available to fit most budgets.
Lucky8 has the spacer kits as well but his appear to be a bit cheaper at $143.00 plus shipping.
Lucky8 Llc. - Take the road less traveled...[Product]/0/
so what your saying is to only buy the spacers for the rear? And then buy 2 inch lift springs for the front to even it out? What damage would the spacers do in the front?
wreckdiver1321
11-30-2012 04:04 PM
