Small leak after oil change
Old Oct 16, 2010 | 09:42 PM
reauxver311's Avatar
7th Gear
Default Small leak after oil change
I just bought an '04 Discovery with right at 80,000 miles. First two weeks, no spots on the driveway. After first oil change, 8-10 spots on driveway the next morning. I washed the engine compartment out and no more "spots" until another 2 weeks afterwards. This morning, a few more spots on the driveway that actually look like they are coming from power steering fluid reservoir. Should I just expect this from my Rover or be concerned?
Old Oct 16, 2010 | 10:18 PM
sloppyjoe's Avatar
a spot here and there is nothing to worry about. a swimming pool is another thing entirely.
Old Oct 17, 2010 | 07:01 AM
Come on Joe, lets give him some help.
What color is the fluid, red or brown? Yes, you should be concerned and it needs to be taken care of.
Old Oct 18, 2010 | 08:53 PM
7th Gear
Thanks for the offer. It's brown and where I notice it on the ground is on the left front side. A local shop put dye in a couple of the reservoirs several days ago and I took it back to them today. They said I need to replace the valve gasket? Weird thing is they said the same thing about the Z71 I just sold.
Old Oct 18, 2010 | 10:53 PM
mwindth's Avatar
If valve cover leak...try tightening the valve cover bolts first; 8mm 12pt...gaskets second
Pjpax
Sep 2, 2014 11:22 AM
COBRA
May 27, 2013 02:17 PM
collin Barrows
Aug 28, 2011 07:13 AM
Sunny side auto
May 29, 2011 03:57 PM
MCKEAG
Mar 24, 2011 11:08 AM
