Smoke Emitting From Under Driver's Seat
Hello,
This last weekend we had a cold snap and sure enough, my battery died, or so I think. When I got out to my vehicle, there was power to the keyless entry, interior lighting, etc. When I went to start though, it would make it maybe a half a turn and then quit while still having enough juice to power everything inside. I found someone to give me a jump however, it took a good 30 minutes to finally get it to turn. Once it started, it drove fine all the way home. The next day, I went to start it and sure enough, it gave me the same problem when it came to starting.
I went and purchased a new battery and installed it today. After connecting the terminals (no, I did not reverse polarities) I went to start it and the same thing happened. It wouldn't turn. I went back under the hood to check the connections and they seemed fine. As I walked back to get in it I saw smoke coming out from under the driver's seat. I quickly ran to disconnect the battery and make sure there was no power anywhere. I kind of freaked out and started pulling all important documentation out of the vehicle because I was afraid it was about to burn down. I tried to see if there was a fire but I did not see any flames. I pulled the seat cushion up and removed the panel at the bottom of the seat. I could definitely smell something had burned however could not see anything charred.
So, it is sitting in my driveway and I have no idea what to do next besides get it towed to a shop. What I would like is some insight from you guys as to what the problem may be and what you think my best options would be. I have never had this problem before and am a bit naive to automotive electrical issues.
Thanks in advance for your input.
2001 Discovery II SE
Last edited by GuidoTheDiscoGuy; 12-22-2009 at 04:31 PM. Reason: Forgot the Model and Year...
The seat heaters are *very* high load items; the manual tells you not to run them without the engine *running* (though apparently it doesn't interlock them).
They're also thermostat controlled. If that thermostat failed ON, then it would cause both of your problems (smoke, and dead battery).
I believe the t-stat goes through the relay, so yeah, pulling the relay is best.
Go to www.landroverresource.com and you can grab the complete set of shop manuals, which will tell you which relay that is. It's 580MB, I hope you have a cablemodem. :-)
earlyrover
08-08-2013 05:36 AM
skatelove303
07-20-2010 06:42 PM
