"Snugging up" the valve cover gaskets
Old Oct 16, 2011 | 06:14 PM
Snafu / Disco Fries's Avatar
Originally Posted by DiscoRover007
I currently have the same leak. It wasn't the valve covers for me(just replaced), pretty sure it's the timing cover gasket, or crankshaft seal.
I think that I have that too. The valve cover is leaking, but not too much. I will get in there and see soon enough, but let us know if you get in and see something else.
Old Oct 16, 2011 | 07:09 PM
DiscoRover007's Avatar
Yeah I will get back to you on it when I know for certain. But after a recent look I can see where the mating surface between the cover and the block is wet, above the oil filter. I think that's where it's coming from. My leak isn't so bad but I plan to have it fixed by the end of the fall.
Old Oct 19, 2011 | 10:25 AM
GreedyRover's Avatar
Originally Posted by agthird
x one million on finding the 12 point 1/4" 8 mm socket...
its not hard to find one...
http://www.amazon.com/Westward-1EZU5.../dp/B001EI1X58
Old Oct 19, 2011 | 03:00 PM
FightOnUSC79's Avatar
Westward 1EZU5 Socket, 1/4 In Dr, 12 Point, 8mm, 1 In L
$3 including shipping
Old Oct 19, 2011 | 04:47 PM
dparham's Avatar
Originally Posted by ljdiscovery
The toughest part of the bolt tightening job is finding a 1/4 inch drive, 12 point 8 mm socket. Once you track one down, hang on to it. Do not get a 3/8 inch drive, it won't work, too fat for the indent in the valve cover. You can ususally snug the two lower bolts on each side, which is good because the leaks generally come from the lower side. You might be able to get to one of the upper bolts, as I recall. Snug them often, spray your engine, top bottom, sides, front and back, with simple green and then a quick rinse with the hose and life is good again. Few things are as good as working on a clean engine. Good luck. Phil
Just purchased one on Amazon PRIME free 2 day shipping! I too seeing little leaking... they sell it for around 6$ or I guess one could get a set...
Old Oct 10, 2013 | 12:20 PM
Mattvail's Avatar
What does v/c mean and where are they located? Thanks for your help in advance.
Originally Posted by Disco Mike
Answer,
Yes, one side is loose, the other isn't. You should make a point of tighten the 2 lower v/c bolts at each oil change cause they do vibrate loose and mechanics love to sell a replacement job for $250 or so since it is easy and usually never needed.
Old Oct 10, 2013 | 12:44 PM
san988's Avatar
V/C = Valve Cover
Old Oct 10, 2013 | 01:05 PM
CaptainCulp's Avatar
v/c refers to the valve covers. I know the rave manual is a bit dense but you can open it in the Adobe PDF reader and use the search function. There are diagrams and detailed descriptions there. I wouldn't recommend tinkering around in the engine compartment without checking the RAVE and following it closely if you don't know where the valve covers are. All of this is stuff that anyone can do, but without a general knowledge of what does what, you could end up accidentally unplugging something/leaning on something critical and end up up a creek.
Old Oct 10, 2013 | 08:35 PM
Mattvail's Avatar
Thanks . Temporary Brain fart on my part
Old Oct 11, 2013 | 02:13 PM
jfall's Avatar
Get the 12 point socket on eBay if you can or amazon.
Or Go to Mc Guckin Hardware in Boulder, CO.
Just tighten a little.
Or you WILL snap the little bolt. They can't tolerate a lot of torque.
