So, I locked myself INSIDE my truck
Old Oct 24, 2014 | 06:03 AM
drowssap's Avatar
you superlocked yourself in, in super lock mode none of the inside door handles work
Old Oct 24, 2014 | 08:42 AM
RicketyTick's Avatar
dreaded superlock...gotta be a way to disable that....permanently!
Old Oct 24, 2014 | 10:27 AM
yup remove all the door locks
Old Oct 24, 2014 | 10:40 AM
Motorhead1's Avatar
I was laughing as I read this too....Only in a Land Rover do you have the fear of locking yourself INSIDE the vehicle....hahahaha
Old Oct 24, 2014 | 11:34 AM
I know you'll never see this on a Toyota forum.
Old Oct 24, 2014 | 11:38 AM
drowssap's Avatar
I;m surprise that they were allowed to get away with that,
i can think of any other car that you could physically lock someone into.
other than a paddy wagon or two i visted
Old Oct 24, 2014 | 11:41 AM
My old 740il did it to. If you locked the car with the fob short of breaking a window you weren't getting out. My wife didn't believe me so she got to stay in the car while I went in for lunch. I waited 5 min and let her out to join me.
The paddy wagon would probably be easier to get out of.
Old Oct 24, 2014 | 11:53 AM
drowssap's Avatar
Old Oct 25, 2014 | 11:06 AM
OCMike's Avatar
I wonder if this would work instead of solder.
Conductive Glue
Old Oct 25, 2014 | 11:33 AM
Conductive Glue
Probably not for long. since it is being pressed alot.
may be good on a wire that never get's touched.
I figure but, I've never tried it.
and about re-soldering the old buttons back on...some have had luck but, my problem with that was, the tabs on the old button that you solder to the board were broken and when you put the solder/heat right on the side of the tiny metal micro button case to resolder, the rubber part of the button inside would fry and not work anymore.
The new buttons I bought had enough tab on them to solder without touching the side of the button case with the soldering tip and heating the button up too much.
Trick is you have to have everything held in place and ready to go when you first touch the soldering tip to it so you don't heat up the new button too much.
One of those little gizmos with the alligator clamps and magnifying glass would be prefect.
I used hemostats to clamp the button in place with a magnifying glass taped onto the top of a stack of books hanging over it. Kind of a rig but it worked for me.
If I had to do it again I'd probably buy one the things mentioned above.
and... if you have not done any soldering before, it's a challenge since you'll be working in about a 1/32" area. I would practice soldering on something else before I tried on the remote's pcb.
You could easily ruin it for good.
If you have an electronics repair place nearby you could take the buttons and have them solder it on for probably less than you'd spend on solder, soldering gun, clamps, etc..
Explain to them it's a $250 + part and not a $10 TV remote and that you want the HMFIC to do the work, not some kid who just started last week.
