So just how good are the brakes on a D2?
Old Jun 30, 2016 | 02:09 PM
Rlozano's Avatar
Default So just how good are the brakes on a D2?
So since I have got my D2 about 5-6 months ago I have noticed that the brakes are not very strong. The pedal feels firm but if I need to come to a sudden stop it just takes it's sweet *** time! Everything seems in order, recently changes to braided lines hoping that would help plus completely flushed out the brake fluid and no change. I went through and checked all vacuum lines for leaks as best I could with no results either. I wonder if maybe that's just how these brakes are normally. Under regular driving conditions it does well but if ever a car was to slam his breaks in front of me I gaurentee I will be in a accident. I have wheeled the car almost every other weekend since I got it with no issues off road either. What are your thoughts?
Old Jun 30, 2016 | 02:54 PM
matt3502's Avatar
What is the state of pads and rotors? I recently replaced all four pads on my 04, bled the brakes, it did seem to help, but compared to other SUV's I have never been thrilled with the brakes. I find that if I step on the pedal and the release it, the brakes seem stronger if I step on the pedal again within a five seconds.
Old Jun 30, 2016 | 03:45 PM
Rlozano's Avatar
Haha, I drive old classic cars so I am already accustomed to double pumping the brake pedal out of habit. My wife makes fun of me because I pump even our brand new cars. Upon inspection of the pads and rotors the seem fine, atlesst 60% life left as far as thickness goes. I found a receipt for brakes from Redwood Land Rover done 2 years ago and the Rover was only driven for 11k from the service mileage. I wonder if from sitting the pads could have gone bad.
Old Jun 30, 2016 | 04:37 PM
Motorhead1's Avatar
I'm not crazy about my brakes either....Mine act the same as yours, AND the fronts will lock up in the snow/ice, you have to be careful. AND if I'm backing down a steep gravel hill, the left front will lock up? I haven't diagnosed it yet. Go ahead and throw out some suggestions if you want
Old Jun 30, 2016 | 04:43 PM
DiscoBuckeye's Avatar
AB swears by using a computer to ABS bleed to have a true firm pedal.
Old Jun 30, 2016 | 05:27 PM
disc oh no's Avatar
Sometimes air gets trapped in the ABS module. The best way to purge the air is activating it with a scan tool. If you don't have a scan tool that has that function, I think there is a procedure you can do using the hill descent button. You might be able to find it somewhere here on the forum.
Old Jun 30, 2016 | 05:57 PM
Street Wolf's Avatar
AB is also run by a bunch of jokes.
Old Jun 30, 2016 | 06:02 PM
Motorhead1's Avatar
I've used hill decent for 10-15 minutes straight on long down hills, I then get a warning light on the dash saying something about the ABS motor getting hot?? I need to do some searching on here, I haven't even looked yet. Could be related in my issue.
Old Jun 30, 2016 | 06:07 PM
mln01's Avatar
In my opinion DII brakes are undersized for a vehicle that weighs as much as our trucks do. The performance you describe is exactly how mine has performed the 14 years I have owned it, through a few brake jobs.
You can spend a lot of time and money trying to improve them but I instead do my best to maintain ample following distance.
Old Jun 30, 2016 | 07:01 PM
matt3502's Avatar
I remember the the thread that talks about using the Hill Descent Control. It was written by a member that i think has left the forum. He told me, in person that every once in a while it was a good idea to engage the HDC. Some times it kept the three amigos at bay for a while. I do it once or twice a year on the hill near me. Can't hurt right?
