So now what?
So now what?
Alright, so far, Have new plugs, new Plug wires (OEM ones now after the NAPA brand failed), New Coil Packs, and a New alternator. Engine is running smooth, very smooth.. In Park. When on the road, spits, and sputters when you give it too much throttle, then the M&S lights start flashing.. again. You can then pull over, turn off the key, start it again, and the problem clears until you give too much jojo... I dunno.. Any ideas? Oh, and Battery has a full charge.. If you sat in it in a parking lot with it running, you'd never know there were problems, your can rev the engine to your hearts content, the second you hit the road, all bets are off, 80% of the time, you get the M&S lights flashing.
2003 Land Rover HSE..
I bought the Alternator at Autozone I'm assuming it's remanufactured, I suspect most of them are nowadays. It is an exact match for the one I replaced though, even the same brand name on the side Valmont or something like that..
The whole vehicle bucks and yaws, but feeling the pedal, there seems to be a "Happy place" during acceleration, where it's running smooth, butt too much accelerator and you get the buck and Yaw, and the M and S lights flashing, too little is the same thing..
SO, I haven't been on here for a while.. I wanted to say thanks to all who had constructive ideas and such it was a big help. The vehicle is running like a champ now. It turned out that the flashing M+S lights and "Limp" mode were due to a bad air bladder on the passenger rear... Apparently whenever I was banking, or taking a sharp turn, the height sensor would get "tripped" for lack of a better word, apparently part of the safety suspension system? Or something like that. Anyhow I replaced both of them on the rear in September 2011, and haven't had a single glitch since.. Hopefully this will come in handy should anyone have similar problems to mine.
hooheehaa
06-23-2005 12:25 PM
