So where did you drill through your firewall?
Old Apr 6, 2015 | 10:52 AM
Broken08's Avatar
Default So where did you drill through your firewall?
I'm just still trying to find the best place to start passing wires through for various electronic upgrades. No place seems "easy"; as in I will have to remove a lot of crap to get through.
So what did you do?
Old Apr 6, 2015 | 10:56 AM
dusty1's Avatar
unused hole with a grommet/ plug under glove box and another by the brake. glove box hole is easier
Old Apr 7, 2015 | 08:40 AM
Lowest Bidder's Avatar
Exactly! I used the hole behind the glove box, real easy way, no drilling.
Old Apr 7, 2015 | 08:59 AM
Broken08's Avatar
Hmm, I don't see that. I didn't mention I have SAI. so behind the glove box is a giant, useless, annoying, loud pump
Old Apr 7, 2015 | 09:56 AM
DustyLBottoms's Avatar
Reach under that pump and you'll feel the rubber plug. I promise it's there! I ran my gauge wiring through the plug.
Old Apr 7, 2015 | 10:04 AM
dusty1's Avatar
pull that piece of junk black cardboard off the knee space below glove box.
may have to fold the carpet back, but you'll see it
Old Apr 7, 2015 | 11:44 AM
cybercop's Avatar
x3 on the rubber grommet behind glove box and under the SAI pump! I just pulled a 4 gauge power line thru it.
Also, next to that towards the fender you will see a large oblonged grommet that has a bunch of wires going thru the bottom portion. Top part is wide open and I pulled my 4 gauge ground thru that!
Old Apr 7, 2015 | 04:13 PM
04duxlr's Avatar
I just poked a small hole through the rubber boot around the main harness on the drivers side and pulled my gauge wiring through there, and then did the same thing on the passenger side to feed my amp but using the other grommets is a great alternative also.
Old Apr 7, 2015 | 06:08 PM
OffroadFrance's Avatar
x4 grommet. I put a 5 core plastic shrouded cable through for various instruments and sealed it in with RTV mastic, it's about the easiest place to find.
Old Apr 7, 2015 | 09:13 PM
bosshogt's Avatar
Thumbs up Main wiring harness boot
2x on the main wiring harness boot top left driver side. I pulled my oil pressure gauge wire and driving lamp wire through a new hole I poked with a punch. I put some marine silicone on the outside and dabbed some on the inside. I could not see any light through so I was comfortable with it.
