soft brakes
soft brakes
Like everyone else, my brakes are a little soft. New pads(akebono's) new rotors ( drilled and slotted). So, with that in mind, what would be the logical route? Brake lines? Booster? Master cylinder? Fluid change? Which of these would make the most impact for more solid braking?? Granted, the lines should be replaced.
[QUOTE=Tomzsix;749057]Like everyone else, my brakes are a little soft. New pads(akebono's) new rotors ( drilled and slotted). So, with that in mind, what would be the logical route? Brake lines? Booster? Master cylinder? Fluid change? Which of these would make the most impact for more solid braking?? Granted, the lines should be replaced.[
you can always throw a master cylinder rebuild kit at it. Should improve that pedal
