soft brakes
Old Nov 6, 2020 | 10:00 PM
Tomzsix's Avatar
Default soft brakes
Like everyone else, my brakes are a little soft. New pads(akebono's) new rotors ( drilled and slotted). So, with that in mind, what would be the logical route? Brake lines? Booster? Master cylinder? Fluid change? Which of these would make the most impact for more solid braking?? Granted, the lines should be replaced.
Old Nov 6, 2020 | 10:56 PM
Jwehking's Avatar
I had everything replaced including brake fluid except for hoses and booster but still did not feel right. Properly bled the system using the power bleeding by jumping the relay and I’m finally satisfied. The bleeding was significant change.
Old Nov 6, 2020 | 10:58 PM
Frank4's Avatar
[QUOTE=Tomzsix;749057]Like everyone else, my brakes are a little soft. New pads(akebono's) new rotors ( drilled and slotted). So, with that in mind, what would be the logical route? Brake lines? Booster? Master cylinder? Fluid change? Which of these would make the most impact for more solid braking?? Granted, the lines should be replaced.[
you can always throw a master cylinder rebuild kit at it. Should improve that pedal
Old Nov 9, 2020 | 03:41 AM
JUKE179r's Avatar
This has been on my ever growing to do list. lol
haasri
Jul 1, 2016 09:47 AM
colinski
Jun 15, 2011 06:56 PM
rich m
Feb 26, 2010 02:09 PM
mattyh007
Sep 22, 2009 09:56 PM
brooksa
Aug 2, 2009 10:01 AM
