Solid lug nuts
Old Oct 21, 2019 | 11:39 AM
Jwehking's Avatar
Default Solid lug nuts
Anyone know of solid lug nuts in 27mm wrench size for stock wheels? Found LA Wheel but theirs are 11/16 and some eBay but 22mm.
Old Oct 21, 2019 | 12:16 PM
Jason Feuerstein's Avatar
The LA wheel nuts are 1 1/16", which is 26.9875mm. You'll be fine using a 27mm socket on them.
Old Oct 21, 2019 | 11:57 PM
Jwehking's Avatar
Haha, I thought the guy went and measured. He could not read? How do you know this? If true, I’ll order. I need 7 as I already had 13 new solid lugs
Old Oct 22, 2019 | 05:55 AM
I don't for certain, and you should definitely confirm, but a visual inspection of the lugs on their website show that the nut is about the same thickness as the shank extension, which is true for the 27mm stock lugs. They're certainly not over a third of an inch narrower.
Old Oct 22, 2019 | 02:48 PM
Jwehking's Avatar
I thought the same. 11/16 is tiny
Old Oct 22, 2019 | 03:53 PM
Llamasayswhat's Avatar
11/16 sure looks a lot like 1 1/16 without a space between
someone goofed on typing it probably
Old Oct 26, 2019 | 06:05 PM
Jwehking's Avatar
Update: I ordered the lugs from L.A. Wheel and Tire. Confirming they are 27mm and solid with chrome. What an upgrade from the capped lugs from LR.
wynhd
Sep 20, 2013 05:52 AM
UpChuck
Apr 19, 2011 09:54 AM
plum1
May 27, 2008 03:17 PM
jeffdarnell
Aug 30, 2007 10:12 AM
dave1070
Jun 14, 2007 08:54 AM
