SOLVED: Three amigos
Old Sep 14, 2020 | 04:53 PM
Brandon318's Avatar
Default SOLVED: Three amigos
Quick recap of the issues and processes:
- Stormy night on the freeway, front-right wheel hit a big pothole going 60mph - three amigos light up.
- Nanocom says the front-right sensor is bad.
- A new ABS sensor was nearly as much as a new hub, so knowing how crusty the hubs were, I opted to just replace both since they include ABS sensor wires.
- Nanocom still says front-right ABS sensor sucks.
- Replaced ABS sensor wire with a known working one. Three amigos remain.
- To remove the connector near the coolant tank as a possible fail point, I ordered a brand new wire that goes straight back through the firewall and to the SLABS unit. Amigos remain.
- Exhausted and out of things to replace, I bit the bullet and bought a fancy new Fluke multimeter and tested for continuity of the ABS sensor from the SLABS unit. The ABS sensor is functioning.
...so, just because I literally had no idea what else it could be, I jacked the wheel up and tested for play in the NEW front wheel hub. Sure enough, it rocks back and forth quite a bit. A new hub was shipped DOA. Swapped a new hub on, cleared the ABS codes with the Nanocom, and ta-da. All fixed and no three amigos after driving it for 25 miles.
Feels good to get this done.
Old Sep 14, 2020 | 07:46 PM
JUKE179r's Avatar
Good Job. Now go knock on some wood for good luck.
Brandon318
Jan 12, 2022 07:54 PM
TheGeeker
Sep 17, 2018 10:16 PM
hemicharger69
Jan 23, 2017 03:37 PM
ukwildcats
Jul 13, 2013 07:30 PM
fjaber
Jan 18, 2007 06:42 PM
