Something strange with 16 inch rims/wheels
Old Sep 10, 2016 | 12:06 PM
Rathwell's Avatar
8th Gear
Default Something strange with 16 inch rims/wheels
Hi amigos, noob here...
Late '99 Disco II
I've just switched out my 18 alloys for 16 inch alloys - and now there is this clicking noise from the rear when I apply the brakes and moving at a slow speed.
The tires went from 255/55R18 to 255/65R16, so not much of a change there, and the new tires are nearly new.
When I switch back to the 18's, then the click is gone... I've checked clearances around the tires/brakes/rims/etc...
The click is definitely a click, and not a thud - can't feel it, just hear it.
Any thoughts?
Rich
Old Sep 10, 2016 | 03:12 PM
aroshan's Avatar
I think you might have a small rock in the tread of your tire or the dust shield might have pealed away the wheel balancing weight from the inside of the rim and it dangling.
Old Sep 10, 2016 | 09:03 PM
Rathwell's Avatar
8th Gear
Thanks for the reply, Aroshan. I've checked those areas - unfortunately those aren't the problem. Kinda worried it's in the drive train somewhere.
Old Sep 11, 2016 | 09:30 AM
Best4x4's Avatar
If it's only with the 16inch rims on it could be a loose center cap, or a set of sticky weights hitting the brake caliper (seen it happen a lot). The only other thing that can click are loose lug nut caps, but you'd have that on the 18's as well.
Old Sep 13, 2016 | 10:05 PM
toofaroffroad's Avatar
Get one front and the opposite side rear off the grounds and spin them. Try to pinpoint the sound.
Old Sep 18, 2016 | 11:22 PM
Rathwell's Avatar
8th Gear
Thanks all for the advice. I've spent as much time as I could (which wasn't as much as I would have liked) under it looking for any sign of potential contact. No luck. Didn't have a chance to jack the whole thing up and spin the wheels - it would have probably revealed the problem. I'm sending it in the The Rover Shop on Tuesday for a valley gasket replacement - I'll ask them to check it out for me.
bacattack
Aug 17, 2011 05:55 PM
Joebern
Jun 21, 2011 05:09 PM
Vincent@CEC
Mar 9, 2011 05:08 PM
Vincent@CEC
Mar 9, 2011 03:15 PM
morfa
Aug 27, 2006 01:22 PM
