Sort of URGENT Engine Info needed CONNECTING ROD HOUSING BORE SIZE
He an I don't communicate well but I believe he is double checking the acceptability of my rods before getting it all back together. My crank had to be turned so I got oversize rod and main bearings.
Using the wrong terminology really confuses the issue and slows getting accurate answers. I was merely guessing what was meant and if I'd seen your reply to me before the other people replied I would have given you the cylinder bore dimensional specs and limitations.
The time spent reading the manual will be more than made up for in timely and accurate replies.
Read through the overhaul manual.
So Abran is trying to find an answer and i'm about to call Cannibal to see if they know--or I would be glad to have it from any source, Tom--but otherwise I'm just going to tell the shop to move to the next thing and hope for the best. The engine project has dragged on and I am well into my limited window for putting it and the transmission in... so I got in.a rush. Sorry. Lack of humility is not one of my faults. I wouldn't ask a question without looking first, and I wouldn't have a land rover but for the generous advice given by gurus such as yourself; wasting your time is not something I would do on purpose.
Per the shop, I need the connecting rod housing bore size (and maximum ovality in the event they are not perfectly round).
He is not resizing them because he already had me find the bearings for them. I think he is just trying to make sure I don't need new rods before he puts them in.
"Sizing" the rods is the term my machinist uses.
The idea is that if there is any oval ness to the shape, they have wear.
The machinist at that point will take off enough material to make them round again, then the 2 flat mating surfaces are decked to make sure the circumference of the hole is correct.
So no amount of oval shape should be tolerable on a newly rebuilt motor.
Now, we just need to know the spec.
Charlie_V (08-21-2015)
That makes perfect sense. Thanks, Abran!
