Sort of URGENT Engine Info needed CONNECTING ROD HOUSING BORE SIZE
#22
#23
#25
Here's the conrod bolt info I was referring to:
Turner Engineering ERR 1772 Conrod Bolt - Set 16
As for clearances, the shop could make sure the big end bore is not out of round, install the new shells and rod to the the crank (using the old bolts) and check the final clearance with plastigauge and, if correct, refit the bearing caps using the new bolts.
#26
METADATA: discovery,4.6,connecting rod housing size or bore,oval,elliptical,crank tunnel,SECRET MEASUREMENTS,WHY CANT THIS BE FOUND,STUPID/BAD/SECRETIVE LAND ROVER/TATA MOTORS,minimum and maximum, SHTF, ovaltine,slurpee,inches for imperialists,RODS,BEARINGS,BORE,keys to success,round,joy,STICKY,closely guarded secret for some reason
HERE IT IS:
low 2.189 (some use 2.187, but 2.189 is generally accepted) to high 2.191, for both 4.6 and 4.0 rods. (NO THAT IS WRONG)
THANK YOU CANNIBAL v8 and all others who searched!
THE OPPOSITE OF A THANK YOU TO D&D!
EDIT: Further thank you to Turner Engineering. The correct answer is 2.313 +/- .0005
Best,
Charlie V
HERE IT IS:
Best,
Charlie V
#27
HERE IT IS:
Best,
Charlie V
HERE IT IS:
Best,
Charlie V
Glad you found the specs you need
#28
On a lark I googled "land rover 4.6 connecting rod big end bore dimensions" and found 2.185"
Buick 215 Rover 3.5 Land Rover 4.0 and 4.6 differences
Then I found this:
HELP! Big end bore spec - Defender Source
I completely forgot about this thread, of course it was 5 years ago.
Then I found this:
2.315" in case someone needs it. And yes, there are procedures for correcting rods--it happens all the time that they get trued up. Just couldn't find the value anywhere.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
#29
Then I found this:
I completely forgot about this thread, of course it was 5 years ago.![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Then I found this:
#30
Well, AC (Tom) is the NINJA OF ALL NINJAS. This morning, all of my rod housings mic'd at 2.3xx. SO I called Steve back and 2.189-2.191 is the JOURNAL measurement (I guess... this is all over my head). We miscommunicated... or I miscommunicated. Anyway, Thanks, AC!!!
So the correct rod bore is 2.315. I asked Steve if there is a range and he said 2.315 so that's what I told the shop and they aren't happy about it.
EDIT: I got another answer from Turner Engineering... see below
