sounds like water trapped in roof 01 disco 2
Water sound
Your drains for the sunroofs could be plugged and not allowing the water to drain down the tubes. The only way to access the drain lines is to drop down the headliner, you will see the lines at the front corners of the pan. You could also try to pour water into the pan from the top with the sunroof open to see if it drains. I had this problem and they were plugged with debris. Be careful, the drain is plastic that has been melted to metal, very easy to break. Good Luck.
