Need help Guy's...SOUNDS LIKE WATER
Old Jun 22, 2009 | 07:23 AM
djmik2000's Avatar
4th Gear
Default Need help Guy's...SOUNDS LIKE WATER
I own A Discovery II 2001 and just recently I noticed that while turning it sounds like there is water behind the dash going side to side on the passenger side.There is no actual leak of water into the vehicle but i do hear water.What could this be and is it a repair that any good mechanic can do or is it a dealer thing?
Thank you like always for all your help.....djmike
Old Jun 22, 2009 | 07:57 AM
Don't be so lazy, do a search on this or any other Rover forum for water noise, read up on it and then get back to us with a specific question.
Old Jun 22, 2009 | 09:05 AM
You are low on coolant, top the cooling system off and take it to a shop to have it pressure tested because you have a leak.
Old Jun 22, 2009 | 01:10 PM
It can also be water not draining from the a/c.
Old Jun 22, 2009 | 03:00 PM
lipadj46's Avatar
Is your passenger side floor soggy? If so clean out your AC drains. Otherwise check your coolant level, if low check for leaks.
evoking
Jan 10, 2012 09:19 PM
jdill732
Apr 2, 2011 08:57 PM
LRXD
Sep 13, 2006 02:24 PM
jmerrill
Mar 5, 2006 01:38 PM
Rovercountry
Oct 7, 2005 09:00 PM
