Source on +6" Goodridge brake lines?
Old Apr 2, 2018 | 12:15 PM
Jeff Blake's Avatar
Default Source on +6" Goodridge brake lines?
My +2" lines are looking rather tight. I found these 4" ones: Goodridge Steel Braided Brake Lines (hoses), 4? extended ? 4-49004 ? Range Rover Classic (US spec)
But am unable to find 6".
Old Apr 2, 2018 | 12:18 PM
Jeff Blake's Avatar
Found these: Discovery II Brake Lines
but they're rather pricey, and I'd prefer Goodridge.
Best4x4's Avatar
I read on another forum that a 99 Toyota Tacoma front brake line is longer vs our D2’s and will work on our D2’s so “if” you can find aftermarket braided SS lines for a 99 Toyota Tacoma then they should be longer vs what you can get for a D2.
Old Apr 2, 2018 | 12:26 PM
Jeff Blake's Avatar
The fronts look compatible:
https://wheelersoffroad.com/i-255071...tegory:1338088
but not the rears:
edit: I'm dumb, use the fronts for the rears...
Old Apr 2, 2018 | 12:44 PM
Alex_M's Avatar
Just get a local hydraulic line shop to make some. They'll be cheaper than finding any online and you'll probably get them quicker.
Old Apr 2, 2018 | 01:18 PM
Jeff Blake's Avatar
What is the hose ID, thread size, pitch, and connection type at each end?
Old Apr 2, 2018 | 01:21 PM
ZGPhoto's Avatar
How much lift do you have? I would be shocked to see you need 6", D2s don't really flex enough to need them
Old Apr 2, 2018 | 01:26 PM
Jeff Blake's Avatar
The front's are fine (with the lower spring seat retainer left unclipped), but I only have about 2" slack in the rears. Hub to arch is 22 3/4", so that's around 3.5"?
And I'd like to do a panhard conversion at some point, so longer lines seem to be a must.
My current lines are 18" in the rear.
I also really need ABS extensions in the rear. The plug popped out on a recent trip (and that was before I put in spacers).
Old Apr 2, 2018 | 01:46 PM
Alex_M's Avatar
Not sure exactly. Just take them an old front and rear and tell them you want them however much longer.
Old Apr 2, 2018 | 01:57 PM
ZGPhoto's Avatar
FYI, I had 6" lines made for my D2 when I had around 3.5" of lift and a panhard conversion. They were WAY too long and had a ton of slack. One of them got pinched eventually. Best to go +4"
