Spare on roof rack?
Old Jan 26, 2013 | 03:50 AM
jleidy's Avatar
Default Spare on roof rack?
Hey Gang,
How many of you keep your spare on the roof rack? I was running into visibility issues out the rear window. It's a bit hard to see around my 32" spare. I just bought a used SD rack and I'm thinking that may be a good place to stick it.
I'm thinking of just fabing some kind of way to secure it to the rack instead of paying near 100$ for a mount.
Any ideas?
Cheers
j
Old Jan 26, 2013 | 08:02 AM
jeffh's Avatar
Have seen it done many many times, the securing is the main issue and the fact that it weighs a wee bit. the distance from up there to down here is pretty far when you are all by yourself.
Old Jan 26, 2013 | 08:51 AM
antichrist's Avatar
I made a bracket for mine and carried it there for a while, but it was a PITA and reduced even further then number of parking garages I could get in to.
I don't find a 32" to obstruct my vision significantly. Then again, my interior rear view mirror fell off about 8 years ago and I haven't bothered to replace it.
Old Jan 26, 2013 | 10:43 AM
Bkreutz's Avatar
You could mount the tire on the bonnet like a Series Rover.
Old Jan 26, 2013 | 11:00 AM
Its going to be a PIA to get it up and down if you get a flat.
Old Jan 26, 2013 | 05:16 PM
roverich's Avatar
I am going to throw mine up there ..Going to get a piece of all thread in the 3/4 in. range about 6 inches long and use a flat piece of 1/4 in. thick aluminum from work about 12 in square . Bolt that to the rack and have the all thread bolted to the aluminum plate . go through the center cap hole of the rim and use a big wing nut to secure it to the rack ..Should work OK i guess , But its gonna be a pain in the tail to remove by yourself.
Old Jan 26, 2013 | 05:21 PM
ZGPhoto's Avatar
I've seen it done a few times. I had a tire up there when I was delivering 4 tires to someone and the wind noise was very much more noticeable.
Old Jan 26, 2013 | 08:19 PM
TRIARII's Avatar
I think the spare would look awesome on the bonnet of a Disco! But you would have the same issue cause the tire would reduce frontal visibility. and it would be a ROYAL pain in the *** to pop open the bonnet for routine repairs or service.
Oasisplayer311
May 7, 2015 09:42 PM
Oasisplayer311
May 3, 2015 03:00 AM
mx468
Sep 19, 2012 07:21 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
