Spare tire carrier removal.
Old May 12, 2010 | 06:34 PM
LR03NJ's Avatar
Default Spare tire carrier removal.
Need help. Want to remove the spare tire carrier on a Disco 2. One bolt is loose and need to be welded. Do I need to remove the interior back panel? Or, just remove the nut from outside the mount? Thank you.
Old May 12, 2010 | 07:34 PM
heromanLSU's Avatar
yep, u need to remove the interior panel. there are nuts on the inside that will fall and rattle around inside the door...i learned the hard way. good luck.
Old May 13, 2010 | 12:53 PM
salve7's Avatar
Remove the back panel being careful not to break the plastic retainers (they are like $1 each if you do), slit the moisture barrier again being careful to leave the plastic in good enough shape to tape back, and underneath that you will wee the bolts that hold the carrier on. Its easy. Good Luck!
Old May 13, 2010 | 02:11 PM
hilltoppersx's Avatar
break all the retainers. pull the sub off. and replace it with a stainless steel panel from Columbia Overland. link on our club site.
Old May 13, 2010 | 02:13 PM
salve7's Avatar
Yeah, then rig up a small table, first aid kit, and fire extinguisher. It will look sweet!
rj95lss
Sep 20, 2010 10:48 AM
jayv
Aug 26, 2009 03:17 PM
roarke
Jun 17, 2009 09:48 PM
kclandrover
Nov 26, 2007 11:36 PM
GrnDisco
Sep 4, 2007 09:02 AM
