Spare tire mount
Old Jul 16, 2021 | 01:52 PM
redrover75's Avatar
Default Spare tire mount
Does anyone know if I can fit a 265 75 15 on the spare mount as if, do I have to flip it over?
Should the nuts that it mounts to be captive? Or do I need to pull the interior panel to hold the back?
I think rust is going to make this much harder than it should be.
Old Jul 16, 2021 | 02:48 PM
The Deputy's Avatar
Needs to be flipped for a 265/75R16, nuts are not captive, must remove inner panel, yes, rust is always a problem.
Old Jul 17, 2021 | 07:10 AM
redrover75's Avatar
Great. Thank you
Old Jul 17, 2021 | 11:13 AM
cvhyatt's Avatar
I just put a 275/70/18 on the back of mine. Didn't have to flip the bracket - just used only two of the lug nuts.
Old Jul 17, 2021 | 06:06 PM
dswilly's Avatar
235/85-16 thats 31.75". Clears the bumper by 3/8" with the mount flipped.
Old Jul 17, 2021 | 09:49 PM
redrover75's Avatar
Default Rack
Originally Posted by redrover75
Great. Thank you
I ended up pulling it off, sanding, prepping, painting and putting it back together. THe spacers were starting to drip rust, so would of had to do it anyway.
Old Jul 18, 2021 | 06:36 AM
mollusc's Avatar
Not a good idea. Only two nuts means you have a horizontal line of potential flex; over time, the combined weight and leverage of the tyre will tear the bolts out of the bracket. With three nuts this is prevented.
Old Jul 18, 2021 | 08:27 AM
cvhyatt's Avatar
I hadn’t thought about that. Good point.
Old Jul 18, 2021 | 06:07 PM
Discorama's Avatar
I made this adapter plate from 1/4" aluminum. No modifications are required. It just requires an M14x1.5 lock nut, an M14x1.5x45 bolt and some washers or a spacer.
DISCODOLO
Jan 13, 2020 08:53 PM
willo
Sep 28, 2015 10:10 PM
ScreamingLife
Oct 9, 2012 05:56 PM
DiscoRover007
Sep 1, 2011 11:47 AM
cst756
Sep 7, 2009 11:48 AM
