Inverting Spare Tire Mount
Old Sep 1, 2011 | 10:56 AM
DiscoRover007's Avatar
Default Inverting Spare Tire Mount
Hey guys so I've decided to reverse my spare tire mount to gain enough clearance so I can put a 275/65/18 tire on the back. It's all going together pretty easily. However I've noticed that reversing the mount pushes the rear wiper blade up some on the window. Will this be a cause for problems? Should I cut a notch in the mount so the wiper will have it's original range? And if I did would I lose some integrity of the mount? Or is it not that big of a deal?
I'm sure some of you guys have done this before. Thanks for the help as always.
Old Sep 1, 2011 | 11:12 AM
You can, as most do, notch out a small area on the carrier so the wiper area will clear.
Old Sep 1, 2011 | 11:47 AM
photocrimes's Avatar
Notch it. That's what I did. I also drilled new holes so I could still use all 6 bolts.
Roverfanatic
Sep 10, 2015 09:41 AM
faturbo
Nov 5, 2009 01:46 PM
rj95lss
Oct 4, 2009 08:58 AM
cst756
Sep 7, 2009 11:48 AM
humroot
Jun 20, 2008 08:19 PM
