spare tire relocator or swing away spare holder
Old Dec 8, 2016 | 04:29 PM
jastutte's Avatar
Default spare tire relocator or swing away spare holder
i currently have 31 inch tires on my truck but have the stock spare on the rear door spare holder. i'd like to pick up another KO2 so all five tires match and i won't be riding lopsided if i end up with a flat.
i'm looking at the spare tire relocater from AB. this would give me clearance for a 31 inch spare.
is this too much weight for the door and hinges? should i just wait and get a swing away? do swing aways work with the stock rear bumper?
i currently have the stock rear bumper and i'm not seriously considering changing that.
Thanks,
Old Dec 8, 2016 | 04:36 PM
LR03NJ's Avatar
Thanks,
I got the tire relocator for 7 years now still have great door allignment. Only 1/2 inch clearance with a 265/65-18 duratrac.
Old Dec 9, 2016 | 03:15 AM
batard's Avatar
The device from AB is pretty solid. It does the trick for me without any hinge issues (at least, not yet). You're only moving the wheel out from the door by about an inch, so it's probably not too big a deal.
The other option, as I'm sure you've read, is to flip the spare holder upside-down, which will put your wheel even higher. The issue there is that it then blocks more of your field of view out the back.
Old Dec 9, 2016 | 06:55 AM
mollusc's Avatar
You also have to rotate the rear wiper on its spline so that it clears the wheel carrier. The wiper will still operate correctly and won't go off the right-hand edge of the window.
Old Dec 9, 2016 | 07:34 AM
Joe!'s Avatar
You could just flip your carrier and have enough clearance, worked with mine with a 265/75/16 and stock rear bumper. Have a swing out now though
Old Dec 9, 2016 | 11:38 AM
jastutte's Avatar
how tall is that tire? i'm running 275/65/18's.
Old Dec 9, 2016 | 11:40 AM
jastutte's Avatar
do you have a photo of that setup? i can't picture it for some reason.
thanks,
Old Dec 9, 2016 | 05:00 PM
mollusc's Avatar
Not really much to it. Instead of the wiper coming to rest parallel with the bottom edge of the window (and the ground), mine stops maybe 15 degrees above flat. The problem is that wiper arm interferes with the wheel mount when you flip it over -- so you have to move the wiper arm around by a couple of teeth.
Old Dec 9, 2016 | 05:12 PM
Alex_M's Avatar
You can also leave the wiper how it is and just trim the carrier to clear it. That's what I did to mine and it works like a dime.
Old Dec 9, 2016 | 05:13 PM
LR03NJ's Avatar
Same here 275/65/18. Im not sure why I was thinking 265?
I was also thinking about the wiper. I did not do anything with the wiper and the tire fitted well.
Probably when you turn the tire carrier the other way. My only concern is that, theres probably
more things to remove like the back speaker panel once you turn it the other way
