spark plug gasket?
Old Aug 13, 2009 | 06:57 PM
jasons's Avatar
Default spark plug gasket?
On a D1 you use the spark plug gasket or does the heads have a taper?
Old Aug 13, 2009 | 07:12 PM
What are on your old plugs??????????????????????????????????????
Old Aug 13, 2009 | 07:17 PM
jasons's Avatar
I threw them away and dont rember. They are on the way to the dump. I could find the answer with the search or in the Rave manual. Either way, I cant be sure the previous owner installed the last ones correctly so I thought I would ask.
Jason
If the plugs come with the crush washer then use the crush washer.
Old Aug 13, 2009 | 07:19 PM
StevenDiscoII's Avatar
Every spark plug includes a flexible metallic sealing ring, right from the box. There is not need to use any other gaskets. It is recommended to apply appropriate anti-seize compound (sparsely) on the plug thread. The threads are straight type, not tapered.
(I hope I understood your question)
Old Aug 13, 2009 | 07:22 PM
Woow, there was responses in this thread when I started typing my post. By the the I finished, threre were two of them right before mine. You guys are fast.
mikedemet
Jan 29, 2021 02:02 PM
CPDieker
Jun 6, 2012 09:36 PM
primey
Oct 26, 2011 07:24 PM
mikedemet
Mar 7, 2006 12:07 AM
kfordric
May 30, 2005 11:29 PM
