Spark plug wires
Old Aug 18, 2009 | 09:15 AM
redhawk's Avatar
6th Gear
Default Spark plug wires
Where is the best place to get after market spark plug wires for a 04 Disco?
Old Aug 18, 2009 | 09:23 AM
You, as a new member on this site, might want to so a search for 8 mm Magnacor wires, one of the most talked about subjects on this and most other Rover sites.
After you do a little of the work, if you then need help on installing them, and you will, then get back to us.
By the way, you will find sites on the section showing those wires for around $90 and shipping.
Old Aug 18, 2009 | 10:12 AM
lipadj46's Avatar
http://www.apexperformance.net/CartGenie/prod-1155.htm
$85.90 + S&H best price on the interwebs as far as I can tell.
Some people on other forums say Kingsborne wires are equal to magnacors at half the price. I went with the magnacors as they are proven. I will let others test the kingsbornes for a while.
Old Aug 18, 2009 | 11:37 AM
antichrist's Avatar
I got by Magnecore from Apex and they were great to deal with. I'd moved my coil and they, or Magnacore, I can't remember which, sent me a longer coil wire free.
Old Aug 18, 2009 | 04:23 PM
AnnelieseMae's Avatar
From: Traverse City, Michigan...currently in Jerome, AZ!
I ordered my 8mm Magnecor wires from http://www.lrrforums.com/store/index...oduct_id=29893
I ordered Bosch 4+ platinum spark plugs at my local auto store.
There is also a tutorial (on the main page of this Disco subforum) on replacing them without having to remove the IM.
Haven't had a problem at all since replacing them. I went with the best as suggested by the fine gents here.
Old Aug 18, 2009 | 05:03 PM
Torancis_LR's Avatar
Get the 8mm Magnecor wires and follow the sticky on the Disco page for installation steps.
Old Aug 18, 2009 | 05:08 PM
I feel as though having ovaries makes my posts invisible. مرة ثانية من فضلك
Old Aug 18, 2009 | 06:04 PM
Its not the ovaries...is the Arabic.
Old Aug 19, 2009 | 04:13 AM
antichrist's Avatar
Wow! And I thought they were expensive from Apex.
Old Aug 19, 2009 | 08:07 AM
britishdiscovery's Avatar
I have just received my set direct from Magnecor in the mail, however they probably didn't understand me because of my accent and sent me the correct set but in 7mm. Is there really a big difference between the 8mm and the 7mm in terms of performance?
I was looking at doing the replacement this weekend, and it will be a pain to have to send them back for a 8mm set.
