Spark plug wires
Old Aug 27, 2007 | 02:01 PM
bigugly82's Avatar
Default Spark plug wires
I'll be changing out my spark plugs and wires this week when they come in. I was looking thru my RAVE manual and can't find anything it there about changing them out.
1. Anyone know where I'd find that info? and
2. About how long of a job am I looking at?
Old Aug 27, 2007 | 03:19 PM
Darover's Avatar
Default RE: Spark plug wires
Go back to the rave and select ENGINE MANAGEMENT SYSTEM, then REPAIRS, and you'll have spark plugs and ignition coil right there
Old Aug 27, 2007 | 03:21 PM
You might want to call me and I'll be glad to walk you thru the process depending on if you have secondary air or not.
We can also talk about Magnacor 8mm wires which is the most popular wires for a Rover.
Old Aug 27, 2007 | 10:39 PM
ajh's Avatar
ajh
Make sure you have an intake cover gasket as well, you'll need that.
Old Aug 28, 2007 | 08:28 AM
You only need the gasket if you are removing the intake manifold. If the truck does not have secondary air and you don't have a hugh hand, you can get it done with out buying the $50 gasket, maybe a six pack and a band aid for after you are done.
Old Aug 28, 2007 | 10:08 AM
chargersfan's Avatar
ORIGINAL: Disco Mike
Thats what I used, the sixer tasted good too. The less parts you have to take off the better!
Old Aug 28, 2007 | 03:59 PM
bigugly82's Avatar
How do I know if it has secondary air?
Old Aug 28, 2007 | 04:06 PM
Call me and I'll walk you thru what to look for.
303-862-7680
Colorado, 7:00 am to 8:00 pm
mikedemet
Jan 29, 2021 02:02 PM
MyRover01
Feb 8, 2008 08:46 PM
Darover
May 22, 2007 08:46 AM
mikedemet
Mar 7, 2006 12:07 AM
kfordric
May 30, 2005 11:29 PM
