Spark Plugs with Stock Wires?
If I switch to the Bosch Platinum plugs will the stock wires work efficiently with them? Wires still seem to be in really good shape. Basically it is 0 degrees farenheit here in MI and changing wires right now is undesireable.
To be honest though, these trucks came with el cheapo Champion copper plugs from the factory.
Are you also using Magnacor wires?
A year or so ago the +4 plugs were talked about being a top choice.
I put them in with new wires about that time with no issues.
Won't change them yet, but when I get the urge?..
DiscoMike, Spike,
what plugs are you guys running?
I have to agree, the biggest thing is the upgrading to 8mm wires (I found some 8.5mm from Aurora ignition wires while in Canada)
DiscoMike, Spike,
