Speedo correction after 255/70/18
Old Apr 20, 2020 | 05:10 PM
Jetfiremuck's Avatar
Default Speedo correction after 255/70/18
Annoyed at speedo reading 5-6mph under actual. Pulled needle off speedo (it’s tight on there) carefully. Got my phone on Speedo drove at 40 pushed needle on and road tested to various speeds. Worked fine . Odometer will still be off I think
Old Apr 20, 2020 | 06:05 PM
redwhitekat's Avatar
Yes it’s normal with bigger tires
Old Apr 20, 2020 | 06:15 PM
Bignacio's Avatar
Im running 265/75/16. I may go to a 33 in tire. Will re-gearing fix the speedo and odometer readings?
Old Apr 20, 2020 | 07:33 PM
You are not regearing. You are putting the speedometer needle where it should read with a gps.
Old Apr 21, 2020 | 08:08 AM
whowa004's Avatar
Re-gearing will not solve that issue Bignacio. Also you might have corrected the needle for a small speed range but it will still be off in other ranges.
Old Apr 21, 2020 | 10:21 AM
no it wont. If the untouched speedo is out by 10mph from 10mph to 100mph relocating the needle to reflect the new speed will be maintained throughout. I’ve done it and it works
Old Apr 21, 2020 | 11:32 AM
Alex_M's Avatar
That's not how it works. Your speedo is thrown off because your tires are a certain percentage larger. If your tires are 10% larger, that throws your speedo off 10%. At 60 mph that would be 6 mph off. At 20 mph that would be 2 mph off. At 100 mph that would be 10 mpg off. Your speedo is still going to be off at other speeds than where you corrected it.
Old Apr 21, 2020 | 12:04 PM
whatever you say........like you’ve done it
Old Apr 21, 2020 | 12:12 PM
whowa004's Avatar
I mean it's just a simple math problem. I'm glad that it works for you but it is not a true solution across all speeds.
Old Apr 21, 2020 | 12:43 PM
Billfromthehill's Avatar
Pretty basic understanding of gear ratio and design will tell you that it only works At a certain speed, like others said, it is off by a percentage. You can say the world is flat all you want, but math really works. And yes re-gearing your differentials to match your tire size will 100% fix the problem the right way. Some vehicles you can buy a speedo cable reducing gear to compensate.
