Spending my tax return..
Well, my taxes finally came back, and I can afford to put some moneys into the rover. Unfortunately it has to be in the form of maintenance items instead of upgrades.
I'm doing front brake pads, an intake gasket kit to fix a small leak, and new plugs and wires. I've got the brakes, and gasket kit in my cart on atlantic british, but I'm a little hesitant on the plug wires. Part of me wants to upgrade to the magnecore 7mm wires, but the cheapskate in me wants to settle for the OEM replacements. So a little schooling on plug wires would be awesome.
Also, since I'm going to have the intake, and cooling system apart, I'm wanting to change out the Dexcool for something that sucks a little less. Is it possible to simply drain the Dex, and refill with another suitable coolant? If so what should I go with?
If you guys have any other input, or tips that would help me along I would more than appreciate it.
Thanks in advance
Thanks in advance
About your plug wires: I believe from what I've read the direct replacement wires are too small of a guage and are cooked by the current and engine heat over time. I also believe the majority of the forum members would recommend 8mm magnacores. I don't mean to speak for them by any means, this is just the impression I get from what I have read. I'm sure someone with some more specific knowledge will chime in. Here is a link to another post with some more info https://landroverforums.com/forum/di...e-wires-24861/ Glad to hear you are taking care of that truck.
Go to Kingsborne Wire Werks Inc - Spark plug wires, Automotive, RV, Motorcycle, Marine, Racing, Industry and get the 8mm wires, much cheaper and they fit perfectly. Don't get the magnacores simply because someone said so.
As for brake pads spend a bit extra on akebono pads, it's worth it. You can get them at amazon or search around a bit, there usual is some place a bit cheaper.
As for the coolant: drain, flush and fill with your favorite color.
Also, just remember to really flush the system out good, especially if you are changing types.
Land Rovers are Full-Time 4WD, not AWD (sorry, pet peeve
![Embarrassment](https://landroverforums.com/forum/images/smilies/r8fZzl5.png)
As for brake pads I just need fronts, so I think I'm going to go with these: Brake Pad Set - EBC Ultimax - Front | Brake Parts for Land Rover & Range Rover
If I drop the coin for akebono's, I want to do all 4.
It might be a horse a piece, but what would be the best coolant option for my rig?
