Spinning bolt on D2 Driver's seat
There's always something goofy when I work on my Rover!
I was trying to remove the driver's seat on my 2003 D2 - there are 4 torx bolts - two are towards the front and two towards the rear.
All 4 bolts are are 7/16 (or 11 mm) torx bolts. The two in front came off no problem. The 3rd bolt (close to the center console) also came off with no problem. But the 4th bolt (rear and close to the driver's door) would just keep spinning.
And no, I've been using tools for many, many years and I did not turn it the wrong way.
How would you handle this problem?
Many thanks
Al
2003 D2 SE7
Many thanks
Al
2003 D2 SE7
i just removed my seat a couple weeks ago to replace the heating element.
That one bolt has a nut on the underside of the floor, a 17mm IIRC.
Hopefully you do not have rust to contend with or it could be a pain.
Good luck!
Good luck!
Thanks
Ridgeline Adventures
Dec 23, 2021 12:18 PM
vp325ica
Mar 9, 2014 11:35 PM
ljdiscovery
Feb 10, 2014 08:58 PM
