Split along seam around thermostat?????
Old Feb 7, 2015 | 10:05 AM
MyRoversNameIsCarl's Avatar
Unhappy Split along seam around thermostat?????
I took out my tstat this morning and found that the seam in the middle seemed to be splitting apart (see pictures). I noticed a weird coolant leak, which is what drew my attention to the tstat. This thing is new, within the past few months, and it is a genuine LR 180 stat.
Do I need to get a new one?
Attached Thumbnails Split along seam around thermostat?????-imag1557.jpg   Split along seam around thermostat?????-imag1558.jpg   Split along seam around thermostat?????-imag1559.jpg
Old Feb 7, 2015 | 11:31 PM
dieselmissfire's Avatar
Toss it buy a new one not worth overheating. I keep one in the back and check fluids every time I fill up the gas well.
Old Feb 8, 2015 | 02:44 AM
buick215's Avatar
Your leak might not be coming from the thermostat. They tend to have that crack where the two halves are fussed together. I would still replace it and see if the leak is resolved, if it is keep the old one as a spare.
Old Feb 8, 2015 | 06:12 AM
OffroadFrance's Avatar
You could pressure test it say to 2-3 bar with a hydraulic pump or compressor but for circa $20 it's not worth the risk of an overheat and head damage. Change it for a new one but check to ensure that is actually what is leaking coolant.
rovernoob
Feb 3, 2015 04:09 PM
KRMusher
Apr 3, 2012 09:43 PM
gtkansan
Apr 26, 2010 10:52 PM
cellman01
Jan 25, 2010 01:41 PM
