Spring spacer thickness
This might be a stupid question, but for the suspension on the D2 does a 1" thick spacer correlate with a 1" lift? I've read that applications on some other vehicles have different ratios but imagine that has a lot to do with the coil spring location in the suspension geometry. I'll probably have the opportunity to machine some out for free in the near future but won't get a chance to install them until spring or summer.
EDIT: For clarification, if I buy something sold as a 1" spacer lift for the D2 which lifts the truck by 1", what is the actual thickness of the spacer?
Thanks for reply but upon reading my initial post I don't think that I posed my question very well. I know that if I buy something called a 1" spacer lift it will increase the height by 1" as you have laid out, however, what I actually want to know/confirm is the thickness of the actual chunk of metal used as the spacer. I assume it's 1" (or near enough) but you know what they say about assuming...
In my experience- when I have sourced coil spacers - they have been milled in 1” increments-
so I have -
pair of front and rear 2”,
pair of front and rear 1” -
which in the beginning I was mixing an matching based on leveling and weight I stock ( bumpers, permanent equipment in back)
I also know for example - that a water pump pulley from a mid 90’s Ford ranger will act as a perfect bolt on rear coil spacer
I have also made my own..
so I have -
Marleystokkson
Defender
09-23-2021 03:20 AM
