Sputtering sounds thru exhaust at idle..........
Old Apr 7, 2008 | 06:33 PM
Phototone's Avatar
Default Sputtering sounds thru exhaust at idle..........
1994 Disco 1, 3.8 V8, 5 sp. Manual. High mileage vehicle. (173,000) Engine starts up from cold great, idles at about 750rpm. Has plenty of power, engine smooth, .....but after engine warms up when coming to a stop sign, and engine drops down to idle..now about 1000 rpm (clutch pushed in, foot brake applied) it will start to produce stuttering sounds (a kind of a rattling) thru exhaust. When I start to accellerate after a second or two the stuttering will stop. I am running premium with a can of seafoam added to gas. I have changed plugs and wires, new air filter, cleaned throttle plate (Butterfly area)..made sure all vacuum connections are secure. I am really at a loss as to what to do. Please note, this is a sound that comes "only" from exhaust, the engine does not have any mechanical sounds at all other than the whirring of normal operation...no ticking or anything.
Old Apr 7, 2008 | 08:11 PM
Default RE: Sputtering sounds thru exhaust at idle..........
After you drive it and the exhaust is hot park it, crawl underneath with a hammer and GENTLY tap on the catalitic converters, if they rattle it means that you need new cats because the baffles are falling apart. It's common so dont worry.
Extinct
Sep 10, 2015 09:53 AM
4x4ron
Sep 3, 2012 09:57 PM
jrm123180
Feb 2, 2012 12:09 PM
themilktruck
Jul 11, 2008 05:35 PM
Phototone
Apr 16, 2008 11:36 AM
