Sqeaking when Accelerating below 40mph
Old Nov 23, 2014 | 01:54 PM
ammonation's Avatar
Default Sqeaking when Accelerating below 40mph
Let me preface this, had the front drive shaft replaced last spring on 99 disco II
Car makes a squeaking sound when accelerating, maybe a little when just in motion, sounds like the belt but its not. It also stops after going over 40mph.
Similar symptoms to when before my drive shaft went, except then it would just shake.
The drive shaft in there is rebuilt, do they need to be greased periodically, or is this shaft just going already.
Could also be a different problem?
Old Nov 23, 2014 | 04:17 PM
cappedup's Avatar
Need to be greased. Did you have fitted a fully serviceable one? Ie, greasable both ends?
The cat runs close to the shaft, and melts the grease out of em.
Do that first off and see how it goes.
Old Nov 23, 2014 | 04:25 PM
ammonation's Avatar
Not sure, bought off amazon or ebay can't even remember. Basic automotive grease?
Grease it on the ujoint?
Old Nov 23, 2014 | 04:26 PM
ammonation's Avatar
Also I take it as your diagnosis of my problem is in fact the drive shaft?
Old Nov 23, 2014 | 05:08 PM
drowssap's Avatar
should be greased every oil change
Old Nov 23, 2014 | 10:48 PM
ammonation's Avatar
mmm just had one a week ago at a jiffy lube... wouldnt depend on them.
Bassmaster
Mar 13, 2014 10:28 AM
flygirl92
Jul 7, 2011 09:00 AM
dqualter
Jan 8, 2011 12:28 PM
justjack
Nov 28, 2008 02:15 PM
JerrodSteph
Sep 21, 2008 11:52 AM
