Squeaking Coming from A/C??
Old Dec 17, 2009 | 02:13 PM
Camdisco24's Avatar
Default Squeaking Coming from A/C??
Recently there has been a little squeaking sound coming from the passenger side of the truck. When I turn off the A/C (or heat) it goes away, so obviously it realted to that. It does not make the sounds all the time, but it for some reason when I push the accelerator it starts the squeaking. It does it on all levels of fan power... It there a fan or belt i should check realted to the A/C on the passenger side?? Is it easy to get to.
I just need some direction on what to look for!! (If i need to clear anything up or give a better description, let me know.)
Thanks!!
Old Dec 17, 2009 | 02:59 PM
okdiscoguy's Avatar
How old is your belt? turning on the a/c adds resistance, and hitting the accelerator adds more. see if the squeak is intermitten or continuous. If it only chirps every revolution on the belt, you may have gottne something on the belt, or it needs to be replaced.
PS, I am envious of the snow you might be getting...
Old Dec 17, 2009 | 03:14 PM
Camdisco24's Avatar
Its intermitten as in it doesnt do it from when I turn on the A/c to when i turn it off. But once it starts squeaking, it is continuous. How easy/hard is it to get to the belt?? Im gonna look on the RAVE cd to see where it is.... I'm guessing its just getting old because i havent changed it in the 3 years ive owned it.
I really hope this storm hits us. They're saying 4 inches for sure, but up to 10 if it hits just right. 4 is alot for Asheville, 10 would be crazy! It would be a great way to start off Chirstmas break with a nice white blanket of snow.
Old Dec 17, 2009 | 05:44 PM
NyTelTech's Avatar
I've had the same problem for some time as well, but in my case, it is coming from the blower assembly. I removed the cover for the blower under the glove box, and sure enough that's where it was coming from. May not be the same problem, but worth giving it a look.
Old Dec 17, 2009 | 05:45 PM
okdiscoguy's Avatar
yeah, change the belt. There is just the one belt. Mine lasts a couple of years on average. If you look on the ribbed side, it will be cracked, if there are more than 2 in an inch, or any chunk is missing, it is toast. At 3 years, though, I would change it
Old Dec 17, 2009 | 06:18 PM
devildog01's Avatar
Originally Posted by Camdisco24
Recently there has been a little squeaking sound coming from the passenger side of the truck. When I turn off the A/C it goes away, so obviously it realted to that. It does not make the sounds all the time, but it for some reason when I push the accelerator it starts the squeaking. It does it on all levels of fan power... It there a fan or belt i should check realted to the A/C on the passenger side?? Is it easy to get to.
Thanks!!
Come on up to NE PA its about 21 degrees here so you wont have any a/c issues!
Old Dec 17, 2009 | 07:47 PM
Camdisco24's Avatar
Thanks for the input everyone, i'll post back with the solution once i get a new belt for it.
May be a little while with Christmas being so close, but I will eventually!
Old Dec 18, 2009 | 12:37 PM
If it is a belt squeak and based on your mileage, I would suggest you replace your 2 idler pullies and the tensioner pulley, cause they all tend to fail squeak and then come apart.
Old Dec 18, 2009 | 12:48 PM
hilltoppersx's Avatar
i don't think i have turned my A/C on since i owned my truck... i do know the heat works damn well.... 12+ inches of snow tomorrow!!! pics to come!
Old Dec 18, 2009 | 02:00 PM
Camdisco24's Avatar
haha, unfortunatly it does it with the heat as well, just the fan being on causes the sqeaking. Mike, thanks for the tip, ill go ahead and replace all that while im at it.
Here in Asheville they are calling for 8-16 inches today and tomorrow, it will be our biggest snow since 1993 if it happens! We are at 4 inches right now and its still coming down hard!! I love it.
